Orbi WiFi 7 RBE973
Reply
Firmware update
j3trooper
Guide
Firmware update
I received an email today from Netgear informing me that a firmware update to firmware version: v1.0.1.44 was available for my router.
As the current version was v1.0.1.42 I followed the download and installation instructions only to be informed that there was no update available.
I tried this several times before going a different route and downloading the zip file with the update. However this would not install as I received an error message that that update was not the correct update.
Can anyone advise if there is an update from my current version and if so how do I go about udating the firmware?
Many thanks
j3trooper
Model: R7800|Nighthawk X4S AC2600 WiFi Router
Message 1 of 10
Accepted Solutions
schumaku
Guru
Re: Firmware update
Yes, that model isn't available in the selection here - not because it's not a Nightawk, much more because it is a DSL router (-> https://community.netgear.com/t5/DSL-Modems-Routers/bd-p/home-dsl-modems-routers )
Firmware, documentation, .... always head to http://www.netgear.com/support/ and ener the model number, like D7800 ...
Current firmware is here: https://www.netgear.com/support/product/D7800.aspx#download - looks like your D7800 is up2date.
Message 9 of 10
All Replies
microchip8
Master
Re: Firmware update
Current version for the R7800 is 1.0.2.60. You should unzip the file and upload the firmware image using the Update page of the Web GUI. Do not use wifi and/or smartphone to perform firmware updates. Always use a wired connection to minimize stuff that can go wrong
Message 2 of 10
IrvSp
Master
Re: Firmware update
V1.0.1.44 is for many routers, and not for the R7800. There is one for the D7800 though, and v1.0.1.42 is the prior version. Sure you don't have a D7800?
If you do, might be better off post HERE in the proper forum.
Message 3 of 10
antinode
Guru
Re: Firmware update
> [...] downloading the zip file with the update. However this would not
> correct update.
   What, exactly, did you downoad?  What, exactly, did you try to send
to the router?  What, exactly, is your router?
> [...] v1.0.1.44 was available for my router.
> As the current version was v1.0.1.42 [...]
   Not consistent.
Message 4 of 10
j3trooper
Guide
Re: Firmware update
As above is the model of Nighthawk router that I have. My model wasn't listed on the drop down menu so I chose the nearest one:)
I only tried to install a firmware update because I had an email from Netgear informing me that there was one available.
My current version of firmware is v1.0.1.42.
If this is not the latest version of firmware for my router can someone kindly advise me what it is.
Thanks
j3trooper
Message 5 of 10
antinode
Guru
Re: Firmware update
   "As above" R7800?  "As above" D7800?  Something else?
   How tough would it be for you to look at the label on your router,
and type the model number here which you find there?  "As above" is not
a useful description.
   Determined how, exactly?
   Visit http://netgear.com/support , put in your (actual) model number,
and look for Downloads.  (For older versions, under Firmware and
Software Downloads, look for "View Previous Versions".)  Find the
kit(s).  Download the kit(s) you want.  Read the "Release Notes" file
for instructions.
   When I do that for "R7800", I don't see anything like "v1.0.1.42".
Hence:
> Not consistent.
   Still true.
   Please stop wasting everyone's time, and provide some basic
information in a clear, unambigouus way.
   The non-psychics in your audience can't see the model number on your
router, and you can't seem to bring yourself to reveal it.  So, no, with
no help from you, I don't think that anyone _can_ advise you as to the
latest version of firmware for your unidentified "my router".
Message 6 of 10
IrvSp
Master
Re: Firmware update
See my reply above to update.
You are in the wrong forum, that is why you can not see ther model as it is not a Nighthawk router but a D7800, a combo unit.
Again, see my post above.
Message 7 of 10
j3trooper
Guide
Re: Firmware update
My router model is, according to the back label is a Nighthawk X4S AC2600 Modem Router Model D7800.
My reference to 'as above' related to the Heading of my reply which stated my model is a 'Nighthawk X4S AC2600 Modem Router Model D7800' Unfortunately that Heading was not displayed in my reply as I would have expected. The current version of my firmware as stated when I log into my Netgear account is V1.0.1.42. The fact that I received the following email from Netgear stating a natural progression of firmware update from .42 to .44 led me to enquire on this forum why I could not update to the latest version.
We've Enhanced Your Product's Security.
Please Update to the Latest Firmware.
Your products have the following updates available:
D7800
Download the latest firmware here
Latest firmware version: v1.0.1.44
Following the instructions to update my firmware resulted in no firmware update found? Then downloading that update and then trying to install it from my hard drive also was not successful.
"You are in the wrong forum, that is why you can not see ther model as it is not a Nighthawk router but a D7800, a combo unit."
It says Nighthawk on the base of my router. Why is this not a Nighthawk router?
That aside, now Forum members can see what model of router I have and my current firmware version, can anyone now advise me if there is an update available?
Message 8 of 10
schumaku
Guru
Re: Firmware update
Message 9 of 10
j3trooper
Guide
Re: Firmware update
Hi,
Thank-you for your understanding response and the links you provided, it is much appreciated.
I've now downloaded and installed the firmware unpdate.
Kind regards
j3trooper
Message 10 of 10
Top Contributors
Discussion stats
  • 9 replies
  • 3834 views
  • 2 kudos
  • 5 in conversation
Announcements
Orbi WiFi 7
