Orbi WiFi 7 RBE973
Reply
Firmware upgrade getting stuck on language file - Nighthawk R7900P
tdavison1962
I am attempting to upgrade my Nighthawk firmware and getting stuck on the message: Upgrading language file. It will not get past this message and upgrade the firmware.
Firmware VersionV1.4.1.68_1.3.28
GUI Language VersionV1.4.1.66_2.1.46.1
Message 1 of 5
Accepted Solutions
Guru
Re: Firmware upgrade getting stuck on language file - Nighthawk R7900P
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
https://kb.netgear.com/24231/How-do-I-back-up-the-router-configuration-settings-on-my-Nighthawk-rout...
Enjoy. 📡
Message 5 of 5
All Replies
Guru
Are you using the routers auto update feature or manually applying the FW update file?
Message 2 of 5
Guru
Message 3 of 5
tdavison1962
Thank you, that worked great
Message 4 of 5
Guru
Enjoy. 📡
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 1575 views
  • 2 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
