Orbi WiFi 7 RBE973
Reply
Having to reboot router at least once per day
Didactylos
Tutor
Ttile says it all really. It is well ventilated, sitting by my desktop Mac.
Model: C7000|Nighthawk - AC1900 WiFi Cable Modem Router
Message 1 of 6
Guru
Re: Having to reboot router at least once per day
Is this in regards to the C7000 modem? if so, Netgear has set up a community forum specifically for the Cable Modem products. Most of the people who watch that forum are more likely to have experience with Cable modems and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Cable-Modems-Routers/bd-p/home-cable-modems-routers
Thank you.
Message 2 of 6
Guru
Message 3 of 6
Not really.
It doesn't tell us why you have to reboot the router. What happens that prompts you to do this?
Message 4 of 6
Didactylos
Tutor
It loses the internet connection and will only pick it up again with a reboot.
Message 5 of 6
Thanks for adding more information, but it still doesn't tell us much.
What do the LEDs on the modem/router look like.
What does "loses the internet connection" mean?
The wifi goes down? Your wired (LAN) devices show some sort of dektop alert?
Apologies for the questions, but there are so many way that something can lose the internet connection that without details about what actually happens rather than vague "it won't work" replies.
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 651 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
