chedyus
Jun 22, 2020Tutor
How to turn off remote management on XR300 ?!
Hi there, so i just got an email about a Security Advisory Notification, in this email it says to turn off Remote Management option but i can`t find it in my settings ( see the image ) where exactly is this setting!?!?! Thanks
If it is affected, better ask in the right forum. You'll get much better responses there
Sort By
- microchip8Master
Your router is not affected as it runs DumaOS
- chedyusTutor
microchip8 wrote:Your router is not affected as it runs DumaOS
Hi micro, thanks for the quick reply but from my understanding in this email it says this product is affected ...
- microchip8Master
