- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
If your R7000P drops WIFI, check that it's not overheating
- Mark as New
- Bookmark
- Subscribe
- Permalink
There is hope, don't throw away your R7000P router for dropped signal. Raise it up off the surface or point a fan at it to keep it cool. When the top of the case was 95 and the bottom was 106, WIFI would drop out. I put mine on some wood blocks, now 84 on top and 95 underneath and works great. Avoid placing in an enclosure or or on top of other electronics such as a cable box or AV receiver.
Soutions that involve resetting or firmware updates might be working just because the radio chips shut off for a few minutes and cool down.
Hope this helps!
Jim
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: If your R7000P drops WIFI, check that it's not overheating
Folks have reported poor grease used for the heat sinks. Some have said they took router appart and replaced the grease with good success.
- Mark as New
- Bookmark
- Subscribe
- Permalink
The R7000P does not use grease, it uses thermal pads. I drilled 52 holes in the top cover, been good ever since.
- Mark as New
- Bookmark
- Subscribe
- Permalink
FYI, to avoid having to do more invasive cooling modification measures, one can install a USB laptop fan under the router to add additional force air cooling. Something I've done since 2010. Works well and keeps routers cool.
One I use:
