PLanetTeck
Mar 08, 2021Aspirant
Issues With Port Fowarding
Ive been trying to port foward to start a Valheim server with my friends but no matter what I cant seem to get the ports 2456-2458 open. Ive opened them through port fowarding on my router, Ive tried disabling my firewall, Ive used sites like canyouseeme.org to see if the ports ere open and got (Error I could not see your service on 67.87.85.*** on port (2456)) Ive been able to open port 25565 for a minecraft server in the past but now I cant seem to open any ports at all. Im not sure what the problem could be.
Sort By
> Model: R7800|Nighthawk X4S AC2600 Wifi Router
Firmware version? Connected to what?
For the usual problems with port forwarding, see:
https://community.netgear.com/t5/x/x/m-p/1859106
> [...] Ive opened them through port fowarding on my router, [...]
How, exactly?
- PLanetTeckAspirant
Thanks for the reply! The firmware version is V1.0.2.80 Im not sure what you mean by connected to what, but im connected to the router via etherent and the router is connected straight to the modem. And this is how I set up my port foward
> [...] the router is connected straight to the modem. [...]
What, exactly, is your (unspecified) "the modem"? Maker? Model
number? Is it a simple modem, or a modem+router, or what?I can't (yet) see your pictures. In-line images must be approved
by a moderator before others can see them. The time required varies.
Attachments have no such limitation. Of course, attachments have their
own one-per-message limitation.> [...] I would asume this is a problem with the server and not my
> router?Deduce, not "assume"? Did you try the local server tests suggested
in that "usual problems" list?
