Orbi WiFi 7 RBE973
Reply
Just bought Netgear Nighthawk AC1900
AngusDalemon
Follower
I know very little about routers. What's the difference between the 2.5G and 5G other then the frequency? Should I be using one or the other for certain things? Xbox, laptop, tablets, cellphones?
Message 1 of 3
thehypnootoad
Luminary
Re: Just bought Netgear Nighthawk AC1900
2.4- longer range, more congestion if in busy city
not as fast as 5 ,not as many channels.
5- more channels less congestion shorter range faster.
Normally 5 best for Xbox but depends on where it is in house and size. Is ssid seperate or together.
Message 2 of 3
Guru
@thehypnootoad is correct.
2.4ghz- much slower and more sensitive to interference
5ghz- much faster but shorter range
I usually recommend that people have higher bandwidth devices like streamers/gaming on 5ghz. lower speed devices like IoT, ereaders, etc should be on the lower 2.4ghz.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 393 views
  • 1 kudo
  • 3 in conversation
Announcements
Orbi WiFi 7
