- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Lost WiFi on Nighthawk X10 R9000 after changing Spectrum cable modem.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I had to upgrade my Spectrum cable modem today from 100 MBS to 400 MBS to permit remote work on a CAE server to be efficient. I had to replace the cable modem to make this happen, and my Internet connectivity problem was solved with the higher speed. However, my 2.4 GHz and 5.8 GHz wireless networks were disabled on the R9000, and I have been unable to restore thier functionality.
If I go into the R9000 Advanced -> Setup -> Wireless Setup menu, all of my historical settings are still enabled. I would post a screenshot if this app permitted that, but it does not. The screeshots are attached in a PDF file below. I can left-click Apply, and after a few seconds the system has been updated. When I return to the Advanced -> Advanced Home menu, I am still showing a RED X on the 2.4 GHz Wireless Settings, 5.0 GHz Wireless Settings, as well as both Guest Networks.
Fundamentally, the wireless networks should be working, but they are not. Does anyone know how to remedy this problem so my WiFi netowrks are active again?
Thanks,
Scott
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
I think I found the WiFi ON/Off button on the top right side of the R9000, which is not obvious since it appears to be flush light, but it is a button. I was able to depress the button, which enabled the 2.4 and 5.8 GHz wireless systems. Thanks for the suggestion, which prevented me from have to rebuild the wirless systems this weekend.
Netgear needs better documentation with photos to assist with finding this button.
Thanks again,
Scott
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Lost WiFi on Nighthawk X10 R9000 after changing Spectrum cable modem.
did you try pushing the wifi on/off button for 2 seconds?
It frequently gets hit and has to be pushed to re-enable.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Did that involve a new modem? Or some tweaks to settings?
Replacing a modem can change your network in ways that wreck the settings on your router, which is remembering how it worked with the older modem.
If the suggestions from @plemans don't work, you may have to reset the R9000 and set it up from scratch.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have rebooted the R9000 several times, which did not fix the problem. Please show me in a photo or screen shot the wifi on/off button you are referring to in your message, and I will try that once I know for certain the exact procedure you want to try.
Thanks,
Scott
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes, I was required to replace my old Spectrum 100 MBS modem with a new 400 MBS modem yesterday, which casued this problem to happen. If I have to press the RESET button on the bottom of the router, then I will have to wait to rebuild the router settings over the weekend since I do to not want to interrupt my work today or tomorrow.
Thanks,
Scott
- Mark as New
- Bookmark
- Subscribe
- Permalink
If you visit the support pages:
Support | NETGEAR
you can feed in your model number and find the documentation for your hardware.
Check table 1 in the manual. LED descriptions.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks again,
Scott
- Mark as New
- Bookmark
- Subscribe
- Permalink
Glad to hear you got it working and it was a simple fix!
Let us know if you have other issues
- Mark as New
- Bookmark
- Subscribe
- Permalink
You are not the first, and won't be the last, to miss that.
