Onyxdutchmal
Mar 22, 2021Follower
Lost WiFi
I am not getting a WiFi Signal. Router has been reset numerous times. Modem is connected and signal is strong there. Was working fine in the morning and then just disconnected. All LED lights seem to be lit correctly
1 Reply
Sort By
Did you try pushing and holding the wifi on/off button for 2 seconds?
