- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Model R6700v3 router with internet connection issues
- Mark as New
- Bookmark
- Subscribe
- Permalink
This router is in a 2nd home which we go to every couple of weeks. Each time we get to the home lately, we have no internet connection. The cable company says it's the router. If I reboot the router, our connection is back. This has been happening since the cable company swapped out our modem for a newer, different model. Is there something wrong with the router or is it not compatible with the new modem? I also have a cell booster plugged into the router. Is it better off plugged into the modem?
Thanks.
Vinny
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Model R6700v3 router with internet connection issues
My Setup | ISP SparkLight | Internet Cable 1000↓/50↑ CAX80 Modem Mode | Wifi Router MK83+ (Router Mode) | and RBK853 (Router Mode) | Switches NG GS105/8, GS308v3, GS110MX and XS505M | Additional NG HW: C7800/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, MR6150, R7000, R7800, R7960P, R8000, R8500, R9000, RAXE500, RAX50, XR450, XR700, XR1000, EX7500/EX7700
- Mark as New
- Bookmark
- Subscribe
- Permalink
I did manage to find the firmware version on my phone app. It is V1.0.4.106. However, when I try to check for updates, I get firmware check error.
- Mark as New
- Bookmark
- Subscribe
- Permalink
There's newer firmware for your router I see1.0.4.120 available on the netgear website which you can apply to the router and see if that helps https://www.netgear.com/support/product/R6700v3.aspx#download
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for the reply. I will certainly try that. However, as I mentioned in an earlier post, when I try to check for an update to my firmware from my phone app, I get a firmware check error. Can this update be done manually somehow?
- Mark as New
- Bookmark
- Subscribe
- Permalink
yea download the file from the site https://www.netgear.com/support/product/R6700v3.aspx#download and go into your routers settings and click on administration and then router upgrade. Where it says "browse" you can select the file for the update to be set manually.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Sounds good. Thanks again.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Why does that not surprise me? It is the default buck passing response.
When the modem changed, did you reset the router and set it up from scratch?
You need to get it to forget any settings it picked up from the old modem.
Just another user with a set of boilerplate macros.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I did not reset the router after the new modem was installed. How do I go about doing that? Sorry, but I'm not that tech savvy.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Fortunately, it is dead easy. No PhD in computer engineering needed. Just a button to press.
How do I perform a factory reset on my NETGEAR router? | Answer | NETGEAR Support
Your firmware is also a couple of versions behind the latest.
R6700v3 Firmware Version 1.0.4.120 | Answer | NETGEAR Support
How do I manually upgrade firmware to my NETGEAR router? | Answer | NETGEAR Support
The reasoning behind the reset is that the router picks up various settings from the modem. So if you change the modem, you need to get it to forget its misspent past.
This isn't guaranteed to get rid of any issues you see, but it is the first thing to try.
- Bookmark
- Subscribe
- Permalink
Thanks for all the help from all who replied to my posts. As I mentioned in an ealier post, this is in a second home and we are not there all the time. When we are there again, I will try all of your suggestions. I hope you all have a very Happy Thanksgiving!
