GoWest
Apr 16, 2021Aspirant
Moving to a new home with my Nighthawk purchased a few months ago
Hello Community,
I will be moving soon to a new home, taking my Nighthawk C7000v2 with me. I purchased it last December.
Are there any special disconnect - reconnect procedures I should follow to make this process go smoothly?
Thanks,
Joe
Sort By
are you changing ISP's?
You'd want to make sure its compatible with your isp- GoWestAspirantYes, I will. It is supposed to be compatible
then it *should* work.
I say should because I've seen an ISP provision a router with a firmware that caused it so others couldn't provision it. I haven't seen it in a while though.
