RBrogen's avatar
RBrogen
Netgear AC1750
This unit was workin fine with Firmware version v1.0.4.84_10.0.58.  I got the notice that there was a firmware upgrade available.  I ran the upgrade and it completely bricked my unit.  It now sits with flashing amber power light.  I've tried to factory reset multiple times and manually TFTP the firmware update as well but tha fails at about 60%.  I bought the unit in Oct 2019 so it is about 1 1/2 old and has been rendered useless by the update and it is no longer covered by Netgear warranty and you can't even get to them to say WTF, your update bricked my unit so help fix it please.
