Orbi WiFi 7 RBE973
Reply
Netgear Centria Reset Button Does't Work
Intel_Graphics
I have a netgear centria router and I lost the password to the router login. I tried pressing the reset button for 10 seconds and I also tried the 30 30 30 reset method, but both of those methods won't reset the router.
Model: WNDR4700|Centria - Storage router
Message 1 of 6
Accepted Solutions
storm1985
Prodigy
Re: Netgear Centria Reset Button Does't Work
Time to buy a new one....
Message 4 of 6
All Replies
storm1985
Prodigy
When you push the reset pin hole did you notice that the power LED is blinking amber or responding? If it doesnt respond when you push the reset then HW might be defective. if under warranty you may call support for a replacement.
Message 2 of 6
Intel_Graphics
The power led doesn't blink amber or respond. My unit is not covered by warranty anymore.
Message 3 of 6
storm1985
Prodigy
Message 4 of 6
Intel_Graphics
Rip
Message 5 of 6
storm1985
Prodigy
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 3350 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
