- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Netgear GS305
- Mark as New
- Bookmark
- Subscribe
- Permalink
Netgear GS305
I cannot figure out how to get multiple computers online at the same time like this device is supposed to allow me to. Does anyone know how I configure my computers to allow this? Thank You
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Netgear GS305
the GS305 is a simple unmanaged switch.
What router is it connected to?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Netgear GS305
You need a external router in between the ISP Modem and the GS305 switch, then you'll be able to connect wired devices to the switch and get internet services. The ISP modem is not a router, just a modem only.
Netgear has set up a community forum specifically for the LAN Switch products. Most of the people who watch that forum are more likely to have experience with Switch products and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Unmanaged-Switches-Forum/bd-p/business-unmanaged-switches
Thank you.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Netgear GS305
Thats a modem. not a router.
you need to go modem----->router---->switch.
Reason why is the isp only assigns 1 public ip address. Its up to a router to take that public ip address and assign private ip addresses.
(very simplified explanation)
Switches don't have that capability.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Netgear GS305
Thanks! Can you recommend an inexpensive cable router? No wireless needed
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Netgear GS305
What speeds do you pay for?
Thats a bit of key as there's fast ethernet (10/100mbps) and gigabit (10/100/1000mbps) devices.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Netgear GS305
I think around 200 mbps but it's not wifi. Just cable. Thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Netgear GS305
Never hurts to have a router that supports wifi. Wifi can be disabled for most of the routers (not the mesh ones) so you have the option of disabling it or using it. I'd look through the routers that are gigabit on the netgear routers page. You can filter by specs you want.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Netgear GS305
to not support wifi, you'd either want to look at the business grade routing solutions or you could check into something like the edgerouter x.
Or just get a standard router and disable its wifi.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Netgear GS305
good point! there's the wifi on/off switch on most routers
