Orbi WiFi 7 RBE973
Reply
Netgear R6400v2 Bricked after update
adriank2003
Hello my Netgear R6400v2 bricked after an update and I have been following netgears tftp article but still no luck.
It constantly retstarts after 30 seconds and the pings for 3 seconds.
Request timed out.
Reply from 192.168.1.1: bytes=32 time<1ms TTL=100
Request timed out.
Model: R6400|AC1750 Smart WiFi Router
Message 1 of 3
Accepted Solutions
adriank2003
Re: Netgear R6400v2 Bricked after update
I have solved my issue it is now working I just used nmrpflash - Netgear Unbrick Utility and waited until I got a ping from the router.
Message 3 of 3
All Replies
antinode
Guru
> [...] I have been following netgears tftp article but still no luck.
   _Which_ "netgears tftp article"?  "Following instructions" or "no
luck" is not a useful problem description.  It does not say what you
did.  It does not say what happened when you did it.  As usual, showing
actual actions with their actual results (error messages, LED
indicators, ...) can be more helpful than vague descriptions or
interpretations.
      https://community.netgear.com/t5/x/x/m-p/1622096
Message 2 of 3
adriank2003
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 4819 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
