- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Netgear R6700v3 Router troubleshooting
- Mark as New
- Bookmark
- Subscribe
- Permalink
My router seems to reset each 48 hours. I have troubleshooted my modem, with no issues there.
Each 48 hours I have to reset (power toggle) the router. You could set your watch to the times they are so close.
Causes?
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
A quick update. so far so good. If the 48-hour repeating of the disconnection has been disrupted or eliminated by the router reset, I do not know at this point.
A quick question though, would you suggest that I disable auto updates a firmware on the router? In the Netgear community I've seen several reports of issues with new firmware upgrades.
As always, I appreciate your help. I'm going to keep this thread going until some time passes and I'm assured that the problem is solved.
Dan
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Netgear R6700v3 Router troubleshooting
Greetings,
Big difference between power cycling and resetting?
Which is it? We suspect you are simply power cycling which is restoring internet connectivity?
Who is the ISP?
What hardware is in font of your Nighthawk? (modem / router, combo)?
How is this device configured (if applicable)?
What FW is the R6700v3 running?
If not the stock firmware, how was the device updated?
If you perform a factory reset, perform set up making only the changes needed to connect, does the intenrt remain stable and connected?
Have you tried an earlier / later version of FW?
What are those results?
- Mark as New
- Bookmark
- Subscribe
- Permalink
which firmware version are you on?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I am simply power recycling, not doing a factory reset.
My ISP is Spectrum internet
FW is V1.0.4.84_10.0.58 and I have not tried an earlier version of the firmware.
I'm making changes to the settings one at a time, and today I turned off the automatic updates, in case they were causing the issue.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@DRESTL wrote:I am simply power recycling, not doing a factory reset.-----trying a reset isn't a bad start.
My ISP is Spectrum internet------wth what modem?
FW is V1.0.4.84_10.0.58 and I have not tried an earlier version of the firmware.------a downgrade is sometimes worth trying after you've tried the factory reset.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Unfortunately my Modem doesnt show a manufacturer... The Model Number apparently is E31U2V1.
i'm trying to accomplish this in stages, so I can keep track of single changes, rather than guess at which multiple stage worked or did not.
I really appreciate your help.
Dan
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
So start with the factory reset. If that doesn't help.
Then try installing firmware version 1.0.3.66, factory reset again, and manually install. (not from backup)
- Mark as New
- Bookmark
- Subscribe
- Permalink
Will do. Thanks again. I'll let you know how it turns out
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Here's a brief update and a quick question. I did the factory reset yesterday, and I suppose I'll wait 48 hours to see if that fixed the problem.
Regarding the above, can you clarify what you mean. I install the firmware, do the reset, and manually install.... but I don't understand what I have to manually install?
You have given me a whole lot of help and I really appreciate it. Best to you and stay safe.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Not sure what the "(not from backup)" you quite means.
The "manually install" advice is usually about installing the firmware. Most experienced users like to do that because automatic updates can go wrong, partly because they rely on being connected over the Internet to the Netgear update server. A more reliable approach is to download the firmware from the website and to follow the bit in the manual:
"Manually Upload Firmware to the Router"
The most common use of the term (not from backup) usually comes after the phrase "manually configure the router".
This is because some people are tempted to reload a saved version of their previous settings, from a backup of their configuration file.
If you do that you run the risk that reloading old settings will bring bugs back from the dead.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@DRESTL wrote:
It does have two ethernet ports in the back, I have no idea if it does Wi-Fi or not.
Oh dear, not conclusive.
The reason for asking is that if there is a bunch of Ethernet ports – usually four, sometimes more – it usually means that your modem is also a router. If that is the case then for an easy life you have to tweak the settings of the modem and router so that only one of them is doing the router job.
Just two ports could mean many things. I am not familiar with that sort of arrangement.
Google suggests that in reality, there is only one port with various phone sockets.
Configuring Spectrum's E31U2V1 : HomeNetworking
- Mark as New
- Bookmark
- Subscribe
- Permalink
I really doubt that it is a router.... I pick up no wifi signal.
Thanks,
Dan
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks. I've got it.
Dan
- Mark as New
- Bookmark
- Subscribe
- Permalink
That is a far from reliable test. In fact, a complete red herring. Even a single LAN port guarantees nothing. It is just an indicator to look for.
A modem can cause issues even without wifi and LAN ports. I have a DM200 DSL modem that, by default, comes with router functions that you have to turn off to avoid clashes with a router.
That is why a proper model number and manual are the best guide.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thank you once again. I'll contact my ISP and find out what brand of router I have and whether it contains wifi.
Dan
- Mark as New
- Bookmark
- Subscribe
- Permalink
I located my modem model
Hitron eMTA modem E31N2V1
Hitron Docsis 3.1 Voice Internet Cable Modem (Does not have built in wireless) E31N2V1
https://www.amazon.com/dp/B07V6WXRB3?tag=duckduckgo-d-20&linkCode=osi&th=1&psc=1
- Mark as New
- Bookmark
- Subscribe
- Permalink
Dan
- Mark as New
- Bookmark
- Subscribe
- Permalink
Depends. If you know updates have caused issues, I'd leave it disabled. When a new update comes out, its worth checking the forums to see how well its worked.
Some device never have an issue, others (see the R7000) are nothing but issues.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
A lot of experienced users disable autoupdate.
The main reason for this is that they like to download the new firmware and run the update manually with a wired connection.
Far too many accounts of "bricked" devices track back to an autoupdate. Manual updates are less likely to cause complaints,although this may be because these are done by experienced users.
An update works 99 times out of 100, perhaps better, an update over a live internet connection. But there is always the rare event when the connection goes down. A manual update will work even with no internet connection.
If you hang around here, you will get to know when new firmware lands. Or you can just do an occasional check. After all, after the initial hardware launch, when bug hunting is most active, the update frequency settles down. It is usually months between new versions.
- Mark as New
- Bookmark
- Subscribe
- Permalink
User | Count |
4 | |
3 | |
2 | |
1 | |
1 |
