Orbi WiFi 7 RBE973
Reply
Netgear r7000p wifi slow nothing fixes it!!
AdamZampa
Follower
I have a netgear r7000p router 200mbps isp service from spectrum. Since day one at two different houses wifi internet tests I get 21mbps download and 4 mbps upload. So frustrating. App shows speed coming into router is over 200mbps but out-of router is slow. Numerous reboots and factory resets do nothing. Please help. If I can't fix this I'm gonna smash this thing with a sledge hammer it's junk!
Message 1 of 2
Guru
Re: Netgear r7000p wifi slow nothing fixes it!!
1. what modem/gateway is it connected to?
2. what firmware is on it?
3. Are you using smart connect?
4. what band are you connected to for wifi testing?
5. What device are you testing on?
6. What wired speeds do you get when you speedtest on it?  (not the using the built in speedtest)
Details are key in helping out
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 408 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
