Orbi WiFi 7 RBE973
Reply
Nighthawk AC3200 - secondary wifi behind Google mesh wifi point - can't connect after Google install
ryanswart
Have Google fiber but their original network box and wifi had terrible wifi coverage.  3 years ago purchased a Nighthawk AC3200 tri-band wifi router to help with coverage and it worked pretty well.  Yesterday Google came out and installed new main wifi point and a second mesh point.  I would still like to use the Nighthawk - the same network names are still there, but when I try to connect to them it says "no internet".  All I did was unplug, move, and plug back in.
Message 1 of 4
Accepted Solutions
Guru
Re: Nighthawk AC3200 - secondary wifi behind Google mesh wifi point - can't connect after Google ins
Message 4 of 4
All Replies
Guru
Is the R8000 in access point mode?
running 2 routers on the network can cause issues.
its called a double nat.
https://kb.netgear.com/30186/What-is-Double-NAT
Message 2 of 4
ryanswart
Admitting my ignorance - I don't know if it's in access point mode.  How do I see the settings and change it if necessary?
Model: R8000|Nighthawk X6 AC3200 Smart WIFI Router
Message 3 of 4
Guru
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 882 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
