Orbi WiFi 7 RBE973
Reply
Nighthawk R6900 won't work with older laptop
Jimd47
My R6900 will not work wireless with an old Compaq Presario but works wireless with my Sony Viao and apple products.    Can rhe R6900 be configured to work with older laptops?  Everything worked well with my old Belkin router.
Model: R6900|Nighthawk AC1900 Smart WiFi Router
Message 1 of 12
Accepted Solutions
Retired_Member
Not applicable
Re: Nighthawk R6900 won't work with older laptop
@Jimd47 wrote:
"WPA-PSK [TKIP] + WPA2- PSK [AES
 yes
Message 9 of 12
All Replies
Is the R9000 broadcasting in all bands? New kit will connect at 5GHz, old stuff will probably be 2.4GHz
Can the old Compaq Presario see any wifi?
You'll have to tell people a bit more about what is going on if you want informed responses.
Message 2 of 12
Retired_Member
Not applicable
wpa.pngolder devices cannot use WPA2
Message 3 of 12
If you can, set up a guest user with no security? But that brings its own problems.
Message 4 of 12
Jimd47
Yes, I had it working wireless on a Belkin54G N router before it went south.   The laptop see the wireless network but when I try to connect it says it connects there is a red "?" On the wireless connection.   If I connect to the router via cat5 I can connect and get online so the issue is with only the wireless.  If I try to repair the connection I get "Windows is unable to find a certificate to log you onto the network".  I do not have a certificate on any other units and only use a password on the router.
Message 5 of 12
Retired_Member
Not applicable
re-read post 3
use the circled in red security
Message 6 of 12
Jimd47
The router is set to "WPA2-PSK [AES]".  Should it work on "WPA-PSK [TKIP] + WPA2- PSK [AES]" or "WPA/WPA2 Enterprise"?   The mode is set to "Up to 600 MPS".   Thanks for the come back.
Message 7 of 12
Jimd47
Thanks for the comeback.
Message 8 of 12
Retired_Member
Not applicable
 yes
Message 9 of 12
The manual (page 240) refers to this in the section Troubleshoot WiFi Connectivity.
"Does your WiFi device support the security that you are using for your WiFi network (WPA or WPA2)?"
If you really want to use this combination of hardware, have you tried setting the wifi security to none, and live with the risks?
Message 10 of 12
Jimd47
Making that one change got it working.    I really appreciate the assistance.
Thanks again
Message 11 of 12
Retired_Member
Not applicable
You're Welcome!
Message 12 of 12
Top Contributors
Discussion stats
  • 11 replies
  • 3537 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
