mj1pate's avatar
mj1pate
Tutor
Mar 08, 2021
Nighthawk R7000, V1.0.9.88_10.2.88, wifi drops
There are numerous posts on these issues.  My R7000 has begun developing more frequent internet outages over the last 6 months. Now the frequency is about every 10 days. The topology picture follows.
For a period, we were getting construction related, Periodic brownouts were driving the extenders nuts until I rebooted them.  I added a compact UPS for each of the R7000 and wifi extenders over a year ago and the extenders have been rock solid since. They never require rebooting. But as mentioned, I have more recent R7000 dropouts.
Booting the TM822 Telephony Modem doesn't help.  Rebooting the R7000 fixes everything.
So, I'm adding a smart power strip switch to sense a few home IOT devices that should always be online, and power cycle the R7000, pending a host outage.
There are numerous switches that very similar and more expensive options for the same. We have reasons as many do that the home network should stay online. I wont know how all this helps for some time, but surely by mid-summer and I'll update.
  • Hmmm.... no pictures are showing up.  I apologize, but I think the content of the post is evident.  I should mention that whereas the smart power switch has 2 "smart sockets", I intend to only use one switchable socket, intended for the R7000.  I don't yet see a need to jokt the modem with power cycle hits until further indications.  Of course, the smart power switch will be plugged into the UPS.
    • plemans's avatar
      Guru
      The R7000's been a problem child for firmware.
      There is a newer version 1.0.11.116 thats been released.
      There's also an agreed upon stable version that works fairly well for most. That'd be 1.0.9.42
      with the R7000, I'd recommend any firmware changes be done over a hardwired connection. After the firmware change, a factory reset and clean install (not from backup) tends to result in the best performance/stability.
      Nighthawk R7000 | AC1900 Smart WiFi Router | NETGEAR Support
      • mj1pate's avatar
        mj1pate
        Tutor
        yeah... the stable version you mentioned has been identified as a fix for some. Like many other WFHome-ers, I'm my own on-site IT tech.  We have a security system, cameras, IOT stuff and the network just needs to work.  With UPS on every access point/extender, my devices should have theoretically been pampered.  After going thru the recommended "reset to factory defaults" action, and spending 4 hours getting everything stably back on a network, and another 3 hours getting the smart power switch set up and tested; I'm very happy to have a watchdog on the R7k.  This is suitable for the semi-monthly outages I have.  I really feel for those going thru daily outages, whatever of the cause.
