- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Nighthawk R7000 dropping connection constantly?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Does anyone have issues with this particular router just dropping connection CONSTANTLY. we JUST bought a few weeks ago and we're super unhappy with it.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Nighthawk R7000 dropping connection constantly?
Tell us a bit more about your experience and you might get better advice. So far we know nothing, not even what "connection" you mean. Wifi, Internet, wired Ethernet? All are connections.
What firmware version do you have on the device?
A number is more useful than "the latest". (It may not be by the time people read this.) There can also be newer versions, or "hot fixes", that do not show up if you check for new firmware in the browser interface.
It might also help if you told people what the modem is in front of this router, if there is one. The model number could be useful. Is it, by any chance, also a router, with a set of LAN ports on the back?
The reason for asking is that a lot of people turn up here trying to put a router behind a modem that is also a router. That can complicate troubleshooting.
Apologies for all the questions. But you can help people to help you by providing the information suggested in this forum's header:
Subject (Include model number and brief summary)
Model (Recommended - Helps the community give the best answers)
Body (Include additional detail including model version, firmware, OS and environment where relevant.)
They are there for a good reason.
- Mark as New
- Bookmark
- Subscribe
- Permalink
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
