Orbi WiFi 7 RBE973
Reply
Nighthawk R7800 VoIP setup
Kilr0y
So.
I wanna connect my ip phone through my router and from my understanding this should be possible with this router but i cant seem to find anything relevant on how to setup it up. Anyone have some experience in this category and would be able to help?
Model: R7800|Nighthawk X4S AC2600 WiFi Router
Message 1 of 6
Accepted Solutions
schumaku
Guru
Re: Nighthawk R7800 VoIP setup
@Kilr0y wrote:
So if i were to get the "Gigaset C530 IP" would that work my router,
or would it be possible to plug it directly into the fiber box on the wall?
Same as the ATA-like VoIP device we talked of before.
As I said, you might have to disable the SIP ALG on the router if your VoIP provider does has deployed some advanced NAT handling capabilities.
Most ISP only assign you a single IP address on a home/consumer/SOHO Internet connection - plugging multiple devices direct to the "WAN" or Internet port will lead to problems - so this is in general a no-no.
Message 6 of 6
All Replies
Kilr0y
Its a box that i am supposed to connect to the router in which i connect the phone. But the boxes name is "Eltek R7121"
Message 2 of 6
schumaku
Guru
Still VoIP, isn't it @Case850?
Depending on your telephony provider, you might have to disable the SIP ALG on the router -> How to disable SIP ALG on your NETGEAR device using the genie interface
Message 3 of 6
schumaku
Guru
And that does make a difference on the VoIP side? Get a cold beer and relax....
Message 4 of 6
Kilr0y
Thanks for the reply. So if i were to get the "Gigaset C530 IP" would that work my router, or would it be possible to plug it directly into the fiber box on the wall?
Message 5 of 6
schumaku
Guru
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 8942 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
