- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Nighthawk ac2300 Lan speed limited to 100mbps
- Mark as New
- Bookmark
- Subscribe
- Permalink
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
It was the cable, I bought a CAT7 cable on Amazon and that is what I was using. I changed it to a CAT6 cable and I am now getting the 1000 MEG speeds. Thank you for your help
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Nighthawk ac2300 Lan speed limited to 100mbps
> I connected a Synology NAS 220+ and it only connects at 100mbps, [...]
Which you determined how, exactly? Amber port-status LED on the
router, or what?
> [...] how can I get it to connect at 1000mbp?
Less defective Ethernet cable?
Assuming that you're right about that speed, there are not many
potential culprits to blame here: Bad port on router, bad port on NAS,
bad cable. Generally, a bad cable is the most likely. Test/substitute
the various pieces to determine which causes the problem.
(Note: "m" = "milli" = 1/1000. "M" = "mega" = 1000000.)
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
https://kb.netgear.com/24231/How-do-I-back-up-the-router-configuration-settings-on-my-Nighthawk-rout...
Enjoy.
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
