Orbi WiFi 7 RBE973
Reply
Nighthawk r6220 force http
cjbuckeye
Is there a way to force an R6220 to only logon through HTTPS and not allow http login?
Thanks!!!
Model: R6220|AC1200 Smart WiFi Router with External Antennas
Message 1 of 4
Accepted Solutions
Guru
Re: Nighthawk r6220 force http
Something that can't be done.
Message 4 of 4
All Replies
Guru
Netgear has set up a community forum specifically for General Router products. Most of the people who watch that forum are more likely to have experience with older routers and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/General-WiFi-Routers-Non/bd-p/home-wifi-routers-general
Have you tried HPPS in the browser? Most likely no as the router is of a older generation.
Thank you
Message 2 of 4
cjbuckeye
https works if I type it in, I'm looking at ways to disable the http access for security reasons.
thanks 🙂
Message 3 of 4
Guru
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 815 views
  • 2 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
