- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Nothing but trouble, frequent disconnects, low speeds, but I think I solved most of it, learn how!
- Mark as New
- Bookmark
- Subscribe
- Permalink
2 weeks in to daily tweaking got me to the point where I was sure it was noise in the line for my Cable Router/Modem so I added 75 ohm coaxial terminator caps to the open coax spots in my house they cost about $3 for 4 of them. It improved the noise on my line a tad, nothing gigantic but it was an improvement, something you might want to try. But I was getting super frustrated, have almost perfect noise levels, but still only getting 200mbs out of my Gig service. I finally figured out that putting the IVP6 on auto config instead of DHCP now has my router receiving the needed information, and Im no longer getting 0.0.0.0 for DNS, IPS, etc etc . but still unable to get more than 200... then I discovered 2 additional problems and now Im getting 950 at my computer, and 950 at my Xbox. I'm still not problem free but getting closer here's how (and please if you have suggestions on my final issue please chime in!):
1) Comcast Tier provisioning: Comcast has the device listed as partially compatible as it only lists the CAX30 (my device) as 949 Mbs (what I'm now getting but other services like COX and Spectrum list it as 1Gb+) but since my tier speed is 1G+ it's saying that my device dosen't meet my speed plan so it places my router under an IVP6 provisional code. I thought that was throttling my speeds but it isn't.
2) ODFMA Channels: What it does do however (I think), is it keeps me from being able to use the ODFMA Downstream and Upstream so I'm not seeing the benifit of that option, not even sure if it's using DOCSIS 3.1. I'm only locking 31 channels instead of 32 and only 5 out of 6 (8?) Upstream bonded channels. The downstream ODFMA does show a frequency and non-primary indicator but doesn't state that it is locked or doing anything.
3) Netgear Armor: After correcting the above and running out of options I decided to turn the Netgear Armor (30 day trial version) back on and what happens to my complete suprise? I start getting all of my full speed back to what it was with the Comcast router/modem 950, (once I got 1100 from the Comcast XB7 but normally it was always 950). I am pretty disappointed that I am forced to use a pay for Armor subscription to get the full use of my device. Had I known that, I never would have bought it but now that I am hundreds of $$$'s deep into their products what choice do I have? I bought thier device to get out from unerneath the foot of an overbearing and intrusive IPS provider only to jump neck deep into and under thiers. You can't win.
4) Scammed: I felt like I did a lot of research before my purchase but next time the first thing I'm going to check is if there are tier speed limitations, they advertise speeds up to 10gbs! Wireless speeds up to 2.5Gbs! only to discover that the IPS provider will only recognize it as below 1Gb which will block you from using the best options, never in a million years did I expect this and I feel completely duped by Netgear with the false and misleading claims, shiny packaging, and hidden subscription fees that unless purchased will keep your speeds 10x below what they advertise and 1/5 of the provider speed you are paying for and you STILL can't use all the options.
5) Misleading Lies: What is the point of having your product certifed by Comcast when you can't use the features of the router? Worse yet Netgear knows it! Digging through thier website will reveal that they acknowledge it is only recognized by Comcast at 800Mbs yet they keep that tidbit of infromation under wraps, and certainly don't make any mention of it on thier packaging or in thier manual but clearly they are more than well aware as they list it on their website and boast their Comcast certification! That's nothing but an out and out purposeful misleading LIE while suckering you into buying their product with the promise of all these wonderful and amazing capabilites of thier device that they know you won't be able to use. I am just sickened by Comcast and now Netgear, this has been nothing but the worst, most time consuming effort in futility I have ever experienced that only resulted into zero beneift and forking out more cash to get right back to the exact same place and slightly less coverage (depsite using their mesh extender that is constantly blocked by Armor! Seriously, WTF is that?!?). The only positive side is that I hate Comcast so much that it's still satisfying to screw them in the process even if that means getting screwed by Netgear.
PLEASE SOMEONE PROVE ME WRONG! I"LL WAIT
And if you know a way from me to get around being provisioned by Comcast, or how to get the router to use the ODFMA capabilites please let me know!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Nothing but trouble, frequent disconnects, low speeds, but I think I solved most of it, learn ho
Please visit and post over in the Cablem Modem forum for the CAX30 model modem:
https://community.netgear.com/t5/Cable-Modems-Routers/bd-p/home-cable-modems-routers
As for Armor, Netgear has set up a community forum specifically for the Armor product. Most of the people who watch that forum are more likely to have experience with Armor and know how to work it better than those of us who follow this "router" forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/NETGEAR-Armor/bd-p/en-home-armor
https://www.netgear.com/landings/armor
Good Luck.
