- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi and Router Connection Issues
- Mark as New
- Bookmark
- Subscribe
- Permalink
Orbi and Router Connection Issues almost everyday. The light on my router always turns to purple and even after rebooting it, it stays the same. I'm pretty frustrated with this as even if the router works It's super slow and I try to reboot it and it becomes purple and takes an entire day to become back normal.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi and Router Connection Issues
Do you mean Orbit routers and satellites? Or is the Orbi router connected to another router on the network?
What firmware version do you have on the device?
A number is more useful than "the latest". There may be newer versions, or "hot fixes", that do not show up if you check for new firmware in the browser interface.
If there is one it might also help if you told people the make and model number of the modem/gateway/ONT that sits between this router and the Internet. Is it, by any chance, also a router, with a set of LAN ports on the back?
I ask because a lot of people turn up here trying to put a router behind a modem that is also a router. That can complicate troubleshooting.
While many questions about routers are generic and could be answered anywhere, some things need specialist knowledge.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Orbi Pro - WiFi for Small Business - NETGEAR Communities
You might like to search there for messages related to your issue.
I will ask the Netgear moderator to move your message.
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
Check for various troubleshooting tips.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
