- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Port Forwarding not showing
- Mark as New
- Bookmark
- Subscribe
- Permalink
Had serveral port forwarding rules set. Just went in to make some changes and NONE of them are showing. If I try to add one I know is there it says it is in conflict with an existing rule, but it isn't showing and therefore I can't edit it either.
This is on a NightHawk RAX200 with firmware V1.0.2.8_1.0.45.
Have rebooted and tried other browsers.
Any help would be appreciated.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
> This is on a NightHawk RAX200 [...]
https://community.netgear.com/t5/x/bd-p/en-home-routers-nighthawk-wifi-ax6
> [...] not so great support.
This is a user forum (and not the most appropriate one), not official
"support".
If the information displayed disagrees with the apparent internal
information, then I'd infer that the firmware is defective, and/or the
settings are corrupt.
Settings reset (and manual reconfiguration)?
Visit http://netgear.com/support , put in your model number, and look
for Documentation. Get the User Manual. Read. Look for "Factory
Settings" and/or "Reset".
Differemt firmware?
Visit http://netgear.com/support , put in your (actual) model number,
and look for Downloads. (For older versions, under Firmware and
Software Downloads, look for "View Previous Versions".) Find the
kit(s). Download the kit(s) you want. Read the "Release Notes" file
for instructions.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Port Forwarding not showing
- Mark as New
- Bookmark
- Subscribe
- Permalink
"support".
Differemt firmware?
for instructions.
- Mark as New
- Bookmark
- Subscribe
- Permalink
And again thank you
