Orbi WiFi 7 RBE973
Reply
Port forwarding
needaclone
Port forwarding
Hi, I've been having problems with port forwarding for about 2 months now. The strange thing is that I've been port forwarding for years on this router and suddenly it just stopped. I've read through other support threads and none of the solutions worked for me.
Thanks in advance
Model: R7000|AC1900 Smart WIFI Router
Message 1 of 10
Accepted Solutions
needaclone
Re: Port forwarding
FTP servers, yes. Although I found the solution: Windows Firewall was blocking the ports I was using.
Message 9 of 10
All Replies
schumaku
Guru
Re: Port forwarding
Check if your ISP has migrated your connection to carrier grade NAT - compare the Google "what is my IP address" with the IP address assigned to the router Internet/WAN port as visible in the router Web UI, e.g. the Advanced tab.
Message 2 of 10
needaclone
Re: Port forwarding
The two IP addresses are the same. Whats should I try next?
Message 3 of 10
antinode
Guru
Re: Port forwarding
   Is that accurate?  Firmware version?
> [...] I've been having problems with port forwarding [...]
   "problems" is not a useful problem description.  It does not say what
you did.  It does not say what happened when you did it.  As usual,
showing actual actions with their actual results (error messages, LED
indicators, ...) can be more helpful than vague descriptions or
interpretations.
   Doing _what_ "with port forwarding"?  Actual port-forwarding rule(s)?
Copy+paste is your friend.
> [...] I've read through other support threads and none of the
   Thanks for the helpful links.  Think for a moment about how little
useful information that non-description conveys to the non-psychics in
your audience.
> [...] The strange thing is [...]
   Even stranger is that you seem to believe that you've provided any
useful unformation at all concerning your problem.
Message 4 of 10
needaclone
Re: Port forwarding
I've been hosting a 3 FTP servers on ports 61, 62, 63 on one computer connected to the router via a cat6 ethernet cable. Firmware version is V1.0.9.64_10.2.64 running on a Netgear Nighthawk R7000. Up till about 2 months ago, these servers were working fine, and after an extensive power outage in my area, a connection from outside my network would not work. They still run and can be accessed on the network from ex. 192.168.1.5, but not publicly.
Other threads that work not successful:
https://community.netgear.com/t5/Nighthawk-WiFi-Routers/R7000-Port-Forwarding-Not-Working/m-p/145563...
<other forums that are not netgear related>
I suspect it might be a problem with my computer, but any insiteyou may have will help.
Thanks
Message 5 of 10
schumaku
Guru
Re: Port forwarding
For one FTP server you need more than one port - especially if the FTP control connection does not operate on the default 21/TCP. On other ports, the FTP ALG won't work. And all three FTP servers must be configured for a dedicated FTP passive port range, which must be forwarded indvidually, too.
Message 6 of 10
needaclone
Re: Port forwarding
Would I need to set a download/upload ports? But previously, all three servers were operational, on "3 FTP servers on ports 61, 62, 63" and were able to send/receive data. Could it be an OS issue on the computer's side? I haven't manually updated the servers but OS updates have rolled out.
Message 7 of 10
schumaku
Guru
Re: Port forwarding
You talk of FTP servers, not SFTP (which is SSH, not FTP), ... do you?
Message 8 of 10
needaclone
Re: Port forwarding
Message 9 of 10
schumaku
Guru
Re: Port forwarding
Wonderful ... still curios why this can work on the non-standard ports. Or the FTP ALG does detect the three ports...
Message 10 of 10
Top Contributors
Discussion stats
  • 9 replies
  • 2637 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
