- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
R6400v2 AC1750 Smart Router is slowing down my internet speed
- Mark as New
- Bookmark
- Subscribe
- Permalink
My R6400v2 AC1750 Smart Router is slowing down my internet speed, purhchsed in 2019.
Firmware Version V1.0.4.120_10.0.91,
I confirmed that Spectrum is providing 110 Mbps to my Modem, but speed test only show 50 mbps.
I was getting 100 mbps up until a week ago, did nothing, but it has dropped.
I tried resettingt to factory settings. But I think it updated to latest Firmware version
Netgear said I need to buy a Tech Help contract to get help.
Can anyone help me with this???
Thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: R6400v2 AC1750 Smart Router is slowing down my internet speed
How are you testing speeds?
Wired?
2.4gh?
5ghz?
What site are you using?
What device are you testing on?
- Mark as New
- Bookmark
- Subscribe
- Permalink
2.4, ookla , server is on portland maine where I live Using an old ASUS A750 laptop
I use to get 110 mbps on it
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have Lenovo for work, 5G connection, it's only getting 20mbps, but I suspect becasue we have a lot of security software
- Mark as New
- Bookmark
- Subscribe
- Permalink
I tested via cable to modem got 110 mbps
- Mark as New
- Bookmark
- Subscribe
- Permalink
2.4ghz is sensitive to interference. I haven't seen many devices other than AX devices hit 100mbps over 2.4ghz.
My AC systems usually hit around 30mbps sustained with peaks of 60-70mbps.
You can try changing what wifi channels its broadcasting on. try 1-6-11.
Is your work laptop using a vpn?
do you have a different device you can test both wired and the 5ghz off?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks, I logged into my router, could not find where I change the wifi channel?
I am not using VPN on the 2.4 machine,
@plemans wrote:2.4ghz is sensitive to interference. I haven't seen many devices other than AX devices hit 100mbps over 2.4ghz.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@JJhebert wrote:
Thanks, I logged into my router, could not find where I change the wifi channel?----
How do I change the wireless channel on my NETGEAR router? | Answer | NETGEAR Support
I am not using VPN on the 2.4 machine, -----Thanks. Reason I ask is 2.4ghz is slow. And VPN's can slow down connections. Thats why I was checking if there was a different device you could test 5ghz on. As well as if you can test your wired speeds. the wired speeds will determine if the router is functioning as it should.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hey Hey - i Used 6 and it's now it's over 100 mbps!!! Thanks.
- Mark as New
- Bookmark
- Subscribe
- Permalink
glad to hear it. Its rarely to not have interference on 2.4ghz.
