Orbi WiFi 7 RBE973
Reply
R6700v2 firmware update brick my router
lolhelloeddie
Follower
So I logged into the admin page where you manage the wireless router. I seen that I had an alert to update my router firmware. So I accepted the update let everything run. When I go back and check up on it the power light is like a orange color and it isn't broadcasting the wifi signal either 2.4g or 5g. I tried to do reset and it won't do it I hold it down for couple of seconds and it don't reboot. Can someone please help me.
Model: R6700|Nighthawk AC1750 Smart WiFi Router
Message 1 of 2
Accepted Solutions
antinode
Guru
Re: R6700v2 firmware update brick my router
> [...] the power light is like a orange color [...]
   Solid?  Flashing?
> [...] it isn't broadcasting the wifi signal [...]
   Wired connection?
   You may be a candidate for the TFTP recovery scheme.  See, for
example:
      https://community.netgear.com/t5/x/x/m-p/1622096#M102004
But you will need a computer with a wired (Ethernet) connection to make
that work.
Message 2 of 2
All Replies
antinode
Guru
   Solid?  Flashing?
   Wired connection?
example:
that work.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 1414 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
