回复
R6900 ip mac bind cause no Internet
kokokobe
version: V1.0.2.26_10.0.45
upnp : on
port forward : on ,
but not working because dhcp ip with my pc lost when pc shutdown after some time ,if dhcp ip not lost that wake on lan will success.
i think reserved IP but not enable ip mac binding will cause the wake on lan problem. but when i enable ip mac binding i can't use some app (some can be used)
1 条消息(共 5 条)
已接受的解答
kokokobe
回复: R6900 ip mac bind cause no Internet
rollback to the version:V1.0.2.6_10.0.37 will fixed the arp ip-mac binding problem
在原帖中查看解决方案
5 条消息(共 5 条)
所有回复
Re: R6900 ip mac bind cause no Internet
Bit hard to follow that, but one thing missing is detail of the modem/gateway/ONT in front of this router.
That can also cause "no Internet".
Perhaps you could also explain why you have configured your router as it is. Something to do with getting Wake-On-Lan to work? (It just does here, with no special router settings.) Maybe someone can come u with ideas on how to achieve the same end result.
2 条消息(共 5 条)
kokokobe
yes i wan to wake-on-lan my pc and remote connect it.
that is ppoe moden. i'm sorry for my pooly english. i try bind ip and mac address then can remote wake on my pc . but critical bug with bind ip and mac address. I remote connect the pc but always lose connection. becase the enable it can effect the lan assign.
but i can remote control the router web control backend.
3 条消息(共 5 条)
kokokobe
i find some same report in this forum . that's ip mac binding big bug as my try . how to report this?
4 条消息(共 5 条)
kokokobe
5 条消息(共 5 条)
讨论统计
  • 4 条回复
  • 4563 次查看
  • 0 个奖励
  • 2 交谈中
