Orbi WiFi 7 RBE973
Reply
R7000 5ghz not stable
ov10mech
Star
Running latest firmware V1.0.9.64_10.2.64 -   Multiple devices connected to the 5GHZ side are very unstable.   If you do a constant ping to the router you can see the dropped packets as shown in attachment   2.4ghz is fine but I need the speed of 5.  I have tried messing with the 5ghz channels with no luck.  This is in a single family home so neightbors are not too close.  Anyone else have this issue and anything I can try.  I need to try another vendor if I cant fix this.  WPA2-PSK [AES] if that matters.  Also did complete factory reset recently.
Model: R7000|Nighthawk AC1900 Dual Band WiFi Router
Message 1 of 6
Accepted Solutions
Guru
Re: R7000 5ghz not stable
Agreed, many people are having issues with the current firmware. You can downgrade to earlier firmwares though. Have you tried this?
@TheEther wrote a great response to someone on how to do so. its here:
https://community.netgear.com/t5/Nighthawk-WiFi-Routers/How-to-Downgrade-Firmware-on-Nighthawk-R7000...
Message 3 of 6
All Replies
ov10mech
Star
After reading through through more posts there seems to be a lot of people having issues with the 5G side.
Message 2 of 6
Guru
Message 3 of 6
ov10mech
Star
I will give that a try.  What version is considered stable?  I only use simple port forwarding and WIFI in the house.
Message 4 of 6
Guru
Nothings ever really perfectly stable or manufacturers wouldn't update firmware. With that said, I've heard good things about the .42 firmware. If you're a more advanced user you can always look into dd-wrt but that'd be a different forum 🙂
Message 5 of 6
ov10mech
Star
Re: R7000 5ghz not stable - fixed
Downgraded last night to V1.0.9.42_10.2.44 - Didnt do any of the factory reset stuff.   It's a world of difference.  Not a single ping lost in hours and noticed the latencey is not all over the place like it was.  The internet seems so much snappier like I am hard wired.   Lesson leared : Dont upgrade just to upgrade.
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 14817 views
  • 6 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
