- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
R7000 - Cannot scan from HP MFP to Laptop. Works if both are wired to router but fails wirelessly.
- Mark as New
- Bookmark
- Subscribe
- Permalink
We have a R7000 wireless router that will not let us scan from a HP LaserJet Multi Function Printer (MFP), to a laptop that is connected wirelessly. If we connect both the Laptop and the MFP to the router with ethernet cables, it works fine. However, it we take that same laptop and unplug the network cable, and connect it wirelessly to the router, the HP complains that it is unable to find network path. Nothing was changed other than going from a wired connection to a wireless connection on the laptop.
We are using \\computername\scanfolder for our network path. If we change the network path to \\192.168.1.25\scanfolder, it works. So I know that the MFP can access the laptop and save files there. I suspect something with the DNS when wireless, but I just cannot figure it out. Any help appreciated. TIA.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: R7000 - Cannot scan from HP MFP to Laptop. Works if both are wired to router but fails wireless
Something to ask the Mfr about since this is there product. They should know.
