- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
R7000 Cutting my download speed in half.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
@SpudLord wrote:
@michaelkenward So to do all of this I just need to make sure I have logged into my router by going to 192.168.1.1 in a web browser then disconnect from the modem. Also I have to have the .42 firmware saved somewhere like my desktop then followe the steps?
If you can login to that address, you've got it.
Indeed, if you can login, you don't even need to disconnect the modem.
Keep a copy of the firmware somewhere convenient. Remember, it arrives as a zip file and you'll need to unzip it before the router will accept it. Those instructions should be in the release notes, which are also on the zip file.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: R7000 Cutting my download speed in half.
What is that modem?
Have you tried different speed test sites?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Is that hardwired speed testing for both or wireless on the router? Make sure you're testing over a hardwired connection.
I'd also recommend looking at your firmware. The R7000 is notorious for having issues with firmware > the .42 version. Its the agreed upon most stable version. if you do try downgrading to it, make sure to factory reset afterward and do a manual install (not from backup).
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
The older firmware is found under the "+view previous versions". Download the version you want, extract it to your computer, and then follow these simple steps. Factory reset after it fully downgrades and reboots. Then manually setup the router. Don't use a backup.
- Click ADVANCED tab > Administration > Firmware Upgrade.
- Click Browse and find the file you just downloaded.
- Click Upload. Do not interrupt the upgrade while the router does this step.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I just mean don't re-install from a backup. The R7000 updated to Armor and I've noticed more people having issues when they re-install from a backup configuration after changing to Armor.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Other wise do you know of some other routers that dont have this problem. They don't have to be a nighthawk. I just neet it to handle up to 500Mbps for download.
- Mark as New
- Bookmark
- Subscribe
- Permalink
log in through the browser and you can disable auto updates.
https://kb.netgear.com/000038662/How-do-I-enable-disable-auto-firmware-update
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
so do it in this order. manually download the firmware to your computer first. (and extract it)
1. unhook the router from the modem
2. Reset the r7000
3. install the firmware to the router over a hardwired connection
4. Reset the r7000 again,
5. disable auto updates.
6. do the full setup on the R7000
- Mark as New
- Bookmark
- Subscribe
- Permalink
2. Reset the r7000
- Mark as New
- Bookmark
- Subscribe
- Permalink
@SpudLord wrote:
@plemans Where in these steps do I conect my router to my modem because how amy I suppose to access my router without internet or is there a way to do that l.
You don't need an Internet connection to work on the router.
Plug your PC into the router and follow the intructions from @plemans .
- Disconnect router from modem
- Plug PC into router
- Reset router
- Install chosen firmware
- Reset router
- Disable autoupdate.
- Turn off router
- Turn off modem
- Plug router into modem
- Turn on modem
- Wait for it to connect to the internet
- Turn on router
You may have to reboot the PC at this stage.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
@plemans
I did what you have said and it did nothing. My Download speed is still being cut in half.
- Mark as New
- Bookmark
- Subscribe
- Permalink
