r4v3n6's avatar
r4v3n6
R7000 WiFi password change not possible?
When I get to Basic - Wireless setting where I can change SSID name, WEP, WPA, WPA2 etc, there is no place for changing the password. I have R7000 with latest firmware V1.0.5.70_1.1.91. Is this a known bug? I have tested both with IE and Chrome web browsers also in case of html code errors. Any other way to change the WiFi passwords?
  • Our engineers have taken note of this and will be fixed in the next official firmware release.
    Thank you!
    • Retired_Member's avatar
      Retired_Member
      you have to select a security BEFORE the option to change password is available  If "none" is selected then no password option is available.
      If this is not the case then reset to factory defaults
      • r4v3n's avatar
        r4v3n
        Tutor
        I did choose both WPA and WPA2, but there is nothing appearing to be able to input a password. :(
        Having to reset all my configuration just to change the password seems very odd. :( This is one of the most basic settings of a router.
  • I hade the same problem. It´s the language setting that is the problem.
    I changed from "Auto" (swedish), in the uppe right corner, to English and then I had the oppertunity to change WiFi password!
    /C
      • Thanks for the tip about English. I works :) It works when I choose English, but fails again when moving back to Swedish (Svenska).
        Can you repro this bug also with Svenska setting? (Wireless = Trådlöst)
