Orbi WiFi 7 RBE973
Reply
R7000 buffer overflow exploit patch
lwagner07
Follower
I have firmware version V1.0.7.12_1.2.5 (need to get the newest one), but have a question.
The recommended firmware patch listed in the Netgear notification is:
Re: R7000 Vulnerability Note VU#582384
The Security Advisory has been updated with more information and beta firmware for some models. Thanks for your patience.
R7000-V1.0.7.10_1.2.3.chk
So, if I install this earlier version, will it mess up my router?  I would assume later versions of the firmware would have that fix already embedded, wouldn't they?
Lew Wagner
Model: R7000P|Nighthawk AC2300 Smart WiFi Router with MU-MIMO
Message 1 of 3
Accepted Solutions
ElaineM
NETGEAR Employee Retired
Re: R7000 buffer overflow exploit patch
The latest firmware (1.0.8.34) for R7000 contains the fix.
The firmware that was indicated in that article is just the firmware that fixed it but moving forward all new fw releases has the fix.
Message 3 of 3
All Replies
IrvSp
Master
This is a question for NG Support to completely answer... maybe @ElaineM can? However I would suspect unless called out in the README for the update as removed it would be.
Message 2 of 3
ElaineM
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 3219 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
