Orbi WiFi 7 RBE973
Reply
R7000 can't get wifi to work
Flipperlee
Ive had r7000 router for 2 yrs works great toll Aug 23 2016. Wifi lights are on and white. I have Internet service good. Hardline works fine but no wifi. Did reboots and reset still no wifi. Devices can see the wifi but says not in range. I'm standing in front of it.
Message 1 of 6
Accepted Solutions
Retired_Member
Not applicable
Re: R7000 can't get wifi to work
If multiple devices have same issue then it would appear your router suffered a hardware failure and needs to be replaced
Message 4 of 6
All Replies
Retired_Member
Not applicable
to clarify.. you did try a factory default reset by holding reset until power led flashes?
Message 2 of 6
Flipperlee
Yes twice did reset and multiple times of reboot or power cycle by unplugging it. If i hardline it to laptop no issue. Only on wifi side. After each attempt made sure all lights are white then proceed to attempt to connect phone via wifi detects it but says out of range
Message 3 of 6
Retired_Member
Not applicable
Message 4 of 6
Flipperlee
Yes both phones n my kids tablets can't connect to the wifi. That suxz
Message 5 of 6
Flipperlee
Ok thanx searay for the help. I couldn't find any other answers on here
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 2648 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
