- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
R7000 has slow Wifi Speeds but correct hard wired speeds.......
- Mark as New
- Bookmark
- Subscribe
- Permalink
I currently own two r7000 routers. One in the basement and one hardwired in the attic as an AP. Both of them worked well with great wifi speeds. All of sudden I updated both of the routers firmware a few months back and now the wifi speeds are horrendous. I get 430Mbps hardwired out of both. But with wifi I can only get 150-200Mbps on 5G band. Thats sitting right on top of them with my iphone 11 Pro and Macbook Pro. What are the chances of both routers having the same exact issues. I've noticed a ton of lag when playing my PS4 that I never use to have until the firmware update. I am paying for 400Mbps via Fios. I have CAT6 going from ONU to R7000 in basement. I am not using their router. Any ideas for a fix....
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Tried downgrading router firmware...Also tried my neighbors new router (non netgear). Got my speeds back...I guess i know what i have to do...
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: R7000 has slow Wifi Speeds but correct hard wired speeds.......
> [...] I updated both of the routers firmware [...]
From which version? To which version? Of course, you did a
Web/forum search for your current firmware version to see if others were
complaining, too, before posting your low-info question here, right?
> [...] But with wifi I can only get 150-200Mbps on 5G band. [...]
And you determined that the router is at fault, not the client
device, how, exactly?
> [...] Any ideas for a fix....
Settings reset and manual reconfiguration?
Load better (older/newer) firmware?
Visit http://netgear.com/support , put in your model number, and look
for Downloads. (For older versions, under Firmware and Software
Downloads, look for "View Previous Versions".) Find the kit(s).
Download the kit(s) you want. Read the "Release Notes" file for
instructions. (In the User Manual, look for "firmware", and,
especially, for a topic like "Manually Upload Firmware to the Router".)
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'd go back to the older firmware. The agreed upon stable version for the R7000 is the 1.0.9.42
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
"Tried" with what result?
> From which version? To which version? [...]
Still a mystery.
> [...] Also tried my neighbors new router (non netgear). [...]
"tried" with what result?
Maker? Model?
> [...] Got my speeds back...I guess i know what i have to do...
You might tell the rest of us. Different firmware? Better router?
Any actual information might be interesting.
