Orbi WiFi 7 RBE973
Reply
R8000 Nighthawk X6 AC3200 only gets half internet speed
DSS1947
Tutor
My ISP bumped my internet speed from 26mbps to 50mbps. My cable modem is hardwired to my computer. When I run tests I still get 26mbps. I called my ISP and they had me bypass the router at which time I got 50mbps. As soon as I reconnected the router I am back to 26mbps. I tried all the router settings that I thought might affect it (I'm just a novice in router protocol), but nothing helped. Any suggestions?
Model: R8000|Nighthawk X6 AC3200 Smart WIFI Router
Message 1 of 4
Accepted Solutions
DSS1947
Tutor
Re: R8000 Nighthawk X6 AC3200 only gets half internet speed
Thanks for the advice guys. I did finally get a chance to reset the router to default and it solved the problem.
Message 4 of 4
All Replies
Retired_Member
Not applicable
Try using default settings, press reset until power Led flashes....the speed using a wired connection to lan port should be close to a direct modem connection speed
Message 2 of 4
Mikey94025
Hero
As searay said, go back to default settings and see if you still lose the speed.  There are some features that you cannot enable without also limiting your network speed thru the router (e.g., QOS, traffic filtering, port forwarding/triggering).  You can search the community posts for "CTF speed" and find other topics that discuss router speed loss.
Message 3 of 4
DSS1947
Tutor
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 3198 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi 770 Series
