Orbi WiFi 7 RBE973
Reply
R8500 console access procedure
How to acces the router remotly?
Message 1 of 12
Accepted Solutions
TheEther
Guru
Re: R8500 console access procedure
You can telnet into router.  You can use a telnetenable executable that's freely available on the Internet (use the correct one for your model).  Alternatively, it may be possible to enable telnet access through a debug menu (e.g. http://routerlogin.com/debug.htm).   I saw a post recently about that.
Once you are in, it's pretty much a BusyBox console.
Message 4 of 12
All Replies
TheEther
Guru
Console access usually refers to access via serial port.  This is different from remote access.  Which one are you asking about?
Message 2 of 12
@TheEther
Let me clarify the question, Is there a way to access the raw datas on the router, such as the way the router sees the USB drives or printer or temperature.
Message 3 of 12
TheEther
Guru
Message 4 of 12
@TheEtherI know 3 stuff to access thru telnet but as you are a wiseman I need to be lectured a bit and to feel less stupid! So do you have some docs or procedure or stuff like this to enlight me a bit!!
Thanks!
Message 5 of 12
TheEther
Guru
I happen to like this page.  It's quite detailed.
Message 6 of 12
@TheEther  I am studying that and get back to you if needed!
Message 7 of 12
@TheEther  do you have this procedure applying to NG official FW?
Because I am currently using the NG FW not the DD version.
Regards.
Message 8 of 12
TheEther
Guru
It should work on stock firmware.  It's been a while since I used stock firmware (maybe a couple of years), but it did work back then.  AFAIK, Netgear has not removed support.
Message 9 of 12
@TheEther  thanks for the reply and as I am a bit of a moron on that topic I'll try to sort it out it will take time!!!!
If you you have a "dumy version" connecting the dots shoot!
Regards from FrogLand smelly cheeses (but divine ones)!!!!
Message 10 of 12
TheEther
Guru
If you are on Windows, then read the section New TelnetEnable on Windows.  There are plenty of examples on the webpage on how to execute it.
Message 11 of 12
@TheEther  thanks I'll educate myself thank to you!! :)!
Message 12 of 12
Top Contributors
Discussion stats
  • 11 replies
  • 5807 views
  • 2 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
