Orbi WiFi 7 RBE973
Reply
R9000-100NAS
Mtnman1
R9000-100NAS
I cant open the VPN license key after setting up the files on my PC. windows 10 how can I get that so I can enter it in the windows VPN set up.
Message 1 of 7
Accepted Solutions
Kitsap
Master
Re: R9000-100NAS
@Mtnman1 wrote:
Yes, I did that. I now understand it more with your explanation. Thanks a bunch.
It can really be a challenge the first time.  I know from experience!
If this resolved your issue, please mark the thread resolved.
Message 7 of 7
All Replies
Kitsap
Master
Re: R9000-100NAS
After you configure your router, you download the Open VPN configuration package.  It is a zip compressed file containing four individual files.
You have to copy the individual files from the zip package and put them in the configuration sub-directory that is created when you install the Open VPN client application on your PC.
Message 2 of 7
Mtnman1
Re: R9000-100NAS
Ok ya I did all that, but it says there's a network cable unplugged? lol
Message 3 of 7
Kitsap
Master
Re: R9000-100NAS
You cannot test your Open VPN setup with a device that is connected to the same network where the Open VPN server is running.
If you have a mobile device, you can shut off the Wi-Fi and test through your cell connection.  If you have a laptop and a mobile device, activate the hotspot on your mobile device and connect your laptop through the hotspot.
On either a mobile device or computer, you have to start the Open VPN application and connect back to the Open VPN server before use.
Message 4 of 7
Kitsap
Master
Re: R9000-100NAS
On your Windows client device, after installation of the Open VPN application did you follow the instructions to rename the adapter?  See attached.
Message 5 of 7
Mtnman1
Re: R9000-100NAS
Message 6 of 7
Kitsap
Master
Re: R9000-100NAS
Message 7 of 7
Top Contributors
Discussion stats
  • 6 replies
  • 1383 views
  • 4 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
