Orbi WiFi 7 RBE973
Reply
R9000
austin01
Follower
R9000
How do i set time windows for kids access?
Message 1 of 2
Re: R9000
Read the manual for Parental Controls or consider a subscription for Circle.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
Check the section in the manual Set Up Parental Controls.
If you are in luck, Netgear has added Circle to your router. It hadn't the last time I looked.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 282 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
