Orbi WiFi 7 RBE973
Reply
Remote management address
ae6dx00
Guide
Where is the remote management address set?  On that screen I just see it listed http://<myname>.mynetgear.com but no place to change it.  When I try to access that address my broser says the security certificate is not valid.  How do I fix this?
Model: R9000|Nighthawk X10 AD7200 Smart WiFi Router
Message 1 of 6
Accepted Solutions
ae6dx00
Guide
Re: Remote management address
It worked in Safari
Message 5 of 6
All Replies
antinode
Guru
> Where is the remote management address set? [...]
   It's the IP address of the router's WAN/Internet interface.
Normally, your ISP determines that, not you.
> [...] When I try to access that address my broser [...]
   Which browser?  Running on what?
> [...] says the security certificate is not valid. How do I fix this?
   Ask Netgear?  I haven't been paying much attention, but I'd guess
that a Web or forum search for the actual error message might find some
previous similar reports.
Message 2 of 6
ae6dx00
Guide
Here is what I' refering to https://kb.netgear.com/23860/How-to-Setup-a-NETGEAR-Dynamic-DNS-account
When I visit the DDNS link to go to my router I get the attached screenshot.
Message 3 of 6
That is probably your browser objecting to what it sees as a security lapse.
What happens with a different browser? Most will have a link that you can click.
For example, here's what I see in Edge:
Chrome has a similar "Get out of jail" link.
Message 4 of 6
ae6dx00
Guide
It worked in Safari
Message 5 of 6
@ae6dx00 wrote:
It worked in Safari
Good feedback. Browser related then.
It might help if Netgear got to the bottom of this and provided some sort of fix.
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 1313 views
  • 1 kudo
  • 3 in conversation
Announcements
Orbi WiFi 7
