- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Replaced older NIGHTHAWK router with a newer one. Can't connect now
- Mark as New
- Bookmark
- Subscribe
- Permalink
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
YEP...
Problem is SOLVED......... Defective router right out of the box... Thanks QA.
I took it back and upgraded to the AC2600 hooked right up no issues.... Who is QA at Netgear....???!?!?!
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Replaced older NIGHTHAWK router with a newer one. Can't connect now
Hi ramhad3,
If you connect your computer wired to the R7300 will you get internet connection?
What are the lights on the front panel of the router?
- Mark as New
- Bookmark
- Subscribe
- Permalink
The only ones blinking are internet and the 2.4 and 5g.
For the love of god someone tell me what I am missing ahhhhhhhhhhhhhhhh&#^$^^$&$^#^@:@
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
The modem is connected to router by a lan cable from the lan port of the modem to he yellow internet port of the router correct ?
What lights are lighting up and what color on the router?
- Mark as New
- Bookmark
- Subscribe
- Permalink
YEP...
- Mark as New
- Bookmark
- Subscribe
- Permalink
I hate when that happens it is the hardest thing to find at first you know the router is new and the network work before you replaced the router so where it did go wrong goes through your head.
All the it is the thing think can not be.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Amen,
I beat my head against the wall for hours cause someone in QA didnt properly test it before the product went out the door.
