stargate69
Nov 09, 2020Tutor
Replacement??
My IP says it's my router's fault that my service has been 'cutting out' ....now I know it's true ....hit reset button ...nuthin...Any other way to make it work?? Or is it time to replace?? Thanx for your response, B C
1 Reply
Sort By
What router do you have?
What firmware is on it?
What modem is it connected to?
What are the led's on it doing?
Describe the "cutting out" in more details. Are devices connected and saying "connected, no internet", is the wifi not broadcasting at all, do wired devices drop, just wireless drops? What exactly is happening?
