ellend708's avatar
ellend708
Follower
Dec 29, 2021
Router slow
I recently moved and my router is extremely slow.  I have the same internet provider, upped my speed and my router is very close to my computer. It worked previously when my computer was on a different floor.
I reset the modem and the router and it still is slow. I plugged my computer into the modem and the speed is very fast. The light where the router plugs into the modem is blinking.  I have reset this more than I should have and have upgraded the firmware. Any help would be appreciated.
1 Reply
  • What firmware is on the router?
    What speeds do you get wired through the R6400?
    What speeds do you get over 2.4ghz?
    What speeds do you get over the 5ghz?
    What devices are you testing on?
    What modem/gateway is the router connected to?
