- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Unable to join network
- Mark as New
- Bookmark
- Subscribe
- Permalink
I've got a bunch of devices connected to my network and they are ruuning great. I bought a new iPad mini and whwn i try to connect, it says "unable to join network".
Since there is no other inducation of error, I don't know how to fix it. A guest came over with another iPad, and same thing. But my laptop is connected fine, hence my ability to enter this message. 🙂
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Try setting manual channel 1, 6 or 11 on 2.4Ghz
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
https://kb.netgear.com/24231/How-do-I-back-up-the-router-configuration-settings-on-my-Nighthawk-rout...
Enjoy. 📡
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Unable to join network
Are you sure the password on the pads is correctly entered?
Try the Forget this Network, turn OFF the wifi radio for 5 seconds then turn back on and try to re-connect.
How is the router configured for wifi settings?
What modes are you using?
What channels are you using?
What security mode do you have set on the router?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Enjoy. 📡
