- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Unit quit working after software upgrade. Model R6900v2
- Mark as New
- Bookmark
- Subscribe
- Permalink
After a software upgrade the unit won't work. Tried reloading the software using Tftpd64 application without success. Tried the reset button and reloading. The power button turns orange upon power up then turns white and flashes.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Unit quit working after software upgrade. Model R6900v2
TFTP isn't the easiest operation to get right.
The fact that you mention Tftpd64 suggests that you are using old instructions. You don't need it. Windows has TFTP built in. You just have to enable it.
How to upload firmware to a NETGEAR router using Windows TFTP | Answer | NETGEAR Support
It might help t follow this video:
Timing is important. You may have to try it several times.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I've used tftp2.exe to unbrick routers in the past and not the windows client tftp. There's videos on youtube that show step by step instruction on "how to unbrick a router" using the tftp2.exe method.
