- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Web address Monitoring Nighthawk R7000
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello all,
I'm new to this not so good at forums please forgive my grammar. Is there a way to set up my Nighthawk R7000 or what setting do I need to utilize in order to see what websites have been visited with in the router? I have two R7000 running on each end of our home and they are used for residential traffic with 2 Computers hard wired and all Iphones and Ipads the kids use are using WIFI at all times from the Nighthawks.
Thank you.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Web address Monitoring Nighthawk R7000
- Mark as New
- Bookmark
- Subscribe
- Permalink
What firmware can I add to the R7000 in order to monitor web sites the kids have visited or any others using our wifi?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thank you so much for the response, but I wouldn't know where to start for put the firm ware on the R7000 but sure would like to.(:
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
https://nextdns.io/
- Mark as New
- Bookmark
- Subscribe
- Permalink
As my luck would have it after following set up I get this:
- Mark as New
- Bookmark
- Subscribe
- Permalink
Your device needs to be in router mode. If you're using another router in front of the NETGEAR one, it won't work. Not to mention that you'll be in a double NAT situation that is really to be avoided, but that's another topic.
You can use the router's Web UI at http://routerlogin.net or http://192.168.1.1 and enter the DNS IPs from NextDNS, for both IPv4 and IPv6. If this is successful, on the NextDNS page it'll show something like "this device is using this configuration with NextDNS" or something like that.
You do not say how you "configured" and what you did on the router.
Go to http://192.168.1.1
Go in the WAN config page
Set 45.90.28.88 as 1st DNS server
Set 45.90.30.88 as 2nd DNS server
if you use IPv6, do:
