Orbi WiFi 7 RBE973
Reply
Why my IP went from residential to business?
Histrovian
I have Charter Spectrum ISP and a Netgear nighthawk ac2400 router.
Im currently unable to login to a gaming server because according to them, my IP is identified as business.
However, When I dierectly connect my modem to my Pc and run a speed test or any sort of test to see if that’s the case, it says residential.
But when I connect from my modem to my router(netgear nighthawkac2400) and then to my pc and run the test again, it says business.
How do I configure it to residential? I live in a residential and confirmed with my ISP that it is indeed residential.
Model: AC2400|Nighthawk AC2400 Smart WiFi Router
Message 1 of 11
Guru
Re: Why my IP went from residential to business?
What spectrum gateway do you have?
Are you using armor, parental controls, or a vpn?
have you tried changing the dns provider? Try googles at 8.8.8.8 or 8.8.4.4  or cloudfare's at 1.1.1.1
What firmware is on the router?
Are you playing on a xbox/ps4-5/what exactly is telling you this?
Message 2 of 11
Histrovian
What’s spectrum gateway and how do I find it?
Im not using any wall or vpn.
Oh just an update, it seems like it is NOT the router that is giving me business classification. I plugged my pc directly to the modem this time and it says “spectrum business?”
It didn’t the first time. I also called my isp and they said it was residential. Very puzzling!
Message 3 of 11
Usually the modem box that connects you to the outside world.
Your problem seems to be with Spectrum.
Message 4 of 11
Guru
did you try a different dns?
Message 5 of 11
antinode
Guru
> [...] according to them, my IP is identified as business. [...]
   I'd start by asking how, exactly, "they" determined that.  To me,
this whole question sounds bogus.  So far as I know, the Internet is not
divided between "residential" and non-"residential".  Where does one go
to see the residentiality of the IP address one has?
   And then, why do "they" care?
> [...] When I dierectly connect my modem to my Pc and run a speed test
> or any sort of test to see if that's the case, it says residential.
   "it"?
   What are the IP addresses being tested in both these cases?
   How, exactly, would _any_ DNS-related information affect how some
(unspecified) entity might view some (unspecified) IP address or other
as "residential" or not (whatever that might actually mean)?
Message 6 of 11
Histrovian
Here's an update. We are using an electrical wifi/internt extender from downstair to upstair. We just reset the two devices this morning and I got a different IP and it no longer say business. We also changed out the router, though I doubt this has anythign to do with it.
So it appears to me that the electrical extender is what's causing the issue!
Message 7 of 11
Histrovian
There is a difference between residential and business internet. Try playing the online game Diablo 2 with a business and let me know the result.
Message 8 of 11
antinode
Guru
> There is a difference between residential and business internet. [...]
   Says who?  What?  Why?
> [...] Try playing the online game Diablo 2 with a business and let me
> know the result.
   You shouldn't hold your breath waiting for that to happen.
   If someone tells you that the sky has turned from blue to a tartan
plaid, do you believe it until you can get outside on a cloudless day to
check?
Message 9 of 11
Histrovian
Alright your replies have been less than helpful. I’ll exit out of this
Message 10 of 11
antinode
Guru
> Alright your replies have been less than helpful. [...]
   You might want to review your answers to my questions, if you're
looking for "less than helpful".  Look for "?".
Message 11 of 11
Top Contributors
Discussion stats
  • 10 replies
  • 764 views
  • 0 kudos
  • 4 in conversation
Announcements
Orbi WiFi 7
